voltage divider with tunnel diode
Discussion in 'General Electronics Discussion' started by bhuvanesh, Feb 26, 2014.
  1. bhuvanesh
    bhuvanesh
    201
    Aug 29, 2013
    how does a tunnel diode in voltage divider configuration act as amplifier.what would be resistance of tunnel diode how it changes with small variation(by adding signal source of 0.3v).thank you in advance
  2. (*steve*)
    25,499
    2,839
    Sounds like homework.
    Consider the effect of negative resistance (calculate the voltage at the output of the divider)
