voltage divider or series current resistor
Discussion in 'Electronic Basics' started by NJM, Mar 5, 2007.
  1. NJM
    NJM Guest
    I am just a beginner so forgive me if this question is stupid.
    On a simple circuit, like 2 LEDs with a 12v supply, which would be better,
    a voltage divider to lower the voltage or a series resistor to restrict
    the current? Or am I completly wrong in my understanding of a voltage
    divider?
    Please correct me if I am wrong, but it seems the divider would actually
    waste some energy because it is being sent to ground.
    What is the determining factor in deciding which to use?
    Is the reason a series resistor with LEDs because the LED has a resistance
    of its own therefore creating a sort of divider?
  2. tempus fugit
    tempus fugit Guest
    An LED MUST have a series resistor to limit the current or it will burn out
    in a fee milliseconds. It's not a question of lowering the voltage, it's one
    of limiting the current to a safe value. LED's need a current of 10-20mA
    through them to glow fairly brightly, so select a resistor for each LED to
    supply this.
  3. HKJ
    HKJ Guest
    When the load uses a constant current a series resistor is enough.
    Sort of.
    For calculating led circuits, try this program:
    http://www.miscel.dk/MiscEl/miscelLeds.html
    It can also do a lot of other electric calculations:
    http://www.miscel.dk/MiscEl/miscel.html
  4. Basic principles:
    LEDs produce light in rough proportion to the current
    passing through them.
    LEDs, like most junction diodes drop a voltage that is not
    proportional to the current through them, the way resistors
    do. Very small changes in voltage produce large changes in
    current. So voltage drive is not practical.
    Different colored LEDs drop different voltages, with shorter
    wavelengths generally dropping more. For example, most red
    LEDs will light with less than 2 volts across them, while
    blue ones often drop more than 3.
    Your method should at least roughly control the current
    passing through the fairy fixed voltage drop of the LEDs.
    The series resistor does that a lot better than the voltage
    divider. Besides, the voltage divider wastes current that
    does not pass through the LEDs.
    So lets say that you want to light 3 green LEDs that drop
    about 3 volts each, when their operating current is in the
    normal range. You select an operating current of about 10 mA
    (because, say, it is safely below their maximum current
    rating and you judge, from some experimentation, that this
    produces a reasonable amount of light). So the LEDs, in
    series, will drop about 6 of the 12 volt supply. The
    resistor must be selected to drop the remaining 6 volts
    while passing about 10 mA. 6V/.01A=600 ohms. The next
    higher standard 5% resistor would be 620 ohms and the next
    lower one would be 560 ohms. Take your pick. The resistor
    will produce some heat, so you might want to check that you
    have one large enough to cook off that power. You can
    calculate the power dumped into the resistor either with
    P=amps times volts, volts squared divided by ohms, or amps
    squared times ohms. Since we are trying to achieve 6 volts
    drop while passing .01 amp, the power is 6V*.01A=0.06 watts,
    so even a 1/8th watt resistor would be large enough.
  5. Byron A Jeff
    Byron A Jeff Guest
    This is a newsgroup for beginners. Welcome.
    While LEDs are voltage controlled devices, the critical parameter is current.
    I think you may have gaps in your understanding of LEDs.
    True. That's how they work.
    The specifications of the LED. Specifically the maximum continuous allowable
    current.
    Interesting question. The answer is no. The LED provides minimal resistance
    once sufficient voltage to light it is present.
    The answer is that an LED (like all diodes) will conduct all available current
    once they turn on. The problem is because of construction, if too much current
    goes across, then the diode burns up.
    So the purpose of the resistor is to limit the amount of current in the
    circuit. Off the top of my head Kirchoff's law states that the amount of
    current across every component in a circuit is equal. A resistor impeads
    current based on its resistance. The LED is a virtual dead short once it
    turns on. So when you combine the two together, the amount of current that
    flows across the LED is the same as the current across the resistor. Hence
    the name current limiting resistor.
    Hope this helps. You don't need a voltage divider. The LED will consume
    whatever voltage required to light it (its forward voltage drop) leaving the
    rest of the voltage to the rest of the circuit (which is the resistor).
    A quick example. I once modified a cheap motion detecting floodlight for
    some security testing by connecting the 120VAC output to the LED of an
    optoisolator. Now since that circuit powered a 150W incandecent floodlight,
    there was well over an amp of power @ 120VAC available. Definitely needed a
    The 2V that the LED actually comsumes is negligable. So to simplify my
    calculation, I used a 130VAC (added some slop) voltage and wanted 15mA across
    the resistor. So:
    V=IR
    130V=0.015A * R
    R = 8666 ohms.
    I think for good measure I used a 10K resistor giving a final current of 13mA.
    Finally I needed to compute the power
    P=VI
    P=130V*0.013A
    P=1.69W
    So I pulled a 2W 10K resistor for the project.
    Finally LEDs (and other diodes) don't care for high reverse voltages either.
    So I put a second visible LED in reverse parallel to the opto LED. So one
    was on for half the AC cycle, and the other on for the other half. Plus it
    gave me a visual indicator of when the motion detector activated.
    Note that all of this occured with a 120 VAC input. No need to divide the
    voltage as long as the current is kept under control.
    Hope this helps.
    BAJ
  6. A little perhaps. When you put the LED into the split off of the the
    divider, you're basically going to be shorting the bottom resistor to
    ground. Not quite because there is a small voltage drop across the
    diode, and thus a small one across the the bottom resistor. Most of
    the voltage will be dropped across the top resistor, so in effect you
    have a current limiting resistor with another resistor that bleeds a
    little bit of current off to ground.
    The voltage divider process depends on the fact that the resistance of
    whatever is being driven by the divider is much greater than the
    Thevenin resistance of the divider (in this case, the upper and lower
    resistances in parallel). If it is, then the output Voltage of the
    divider given by the Voltage Divider equation. If it isn't, then the
    output voltage sags due to the voltage dropped across the upper
    resistor.
  7. MassiveProng
    MassiveProng Guest
    Fairly good answer aside from you being a top posting Usenet retard.
    You seem to forget that there are 1 amp LEDs now.
    Yes, OP (original poster), they MUST be current limited, and that
    limit is defined by their declared specs from their manufacturer.
