S
[email protected]
I'm designing a PCB that needs to provide several bias currents to a
custom IC. The receiving end in the IC are basic current mirrors, i.e.
the input stages are diode-connected MOSFETs.
There are several constant currents that I need to source, ranging
from 1uA to 100uA. I plan to use LM234's with trimpots for these. What
is your opinion on using them for such small currents?
There is also a current that needs to be voltage controlled, so I can
change its value using a bench power supply, instead of tuning a
potentiometer. The current range from 100uA to 500uA. I may also
connect it to a waveform generator someday (a sub-MHz frequency). I'm
planning to use a opamp driving a MOSFET for this. The circuit is
similar to this one http://www.edn.com/contents/images/233726f2.pdf
I would like to use LT1801 for the opamp because it is easy to use
(single-supply, rail-to-rail), and seems to have decent performance.
My question is what MOSFET or JFET should I use? I see thousands of
choices on Digikey. Which one should I pick to have the best accuracy
for my application?
Thanks a lot,
Scott
for my application?
Thanks a lot,
Scott
