voltage bucking!
Discussion in 'Electronic Basics' started by Natty, Sep 11, 2005.
  1. Natty
    Natty Guest
    hi
    can someone help on voltage bucking configuration/connection? wat does
    it mean?
    thanx in advance
    Natty.
  2. PeteS
    PeteS Guest
  3. Ralph Mowery
    Ralph Mowery Guest
    If a transformer has several windings and they are connected in series they
    will either add or substract from the total voltage. That is called series
    aiding or series bucking.
  4. ehsjr
    ehsjr Guest
    Simple "buck" circuit analogy:
    +12V- -1.5V+
    +---Batt---+---Batt---+
    +--------Rload--------+
    The 1.5 volt battery "bucks" the 12 volt battery, resulting
    in 10.5 volts across Rload
    For completeness, here's a "boost" circuit:
    +12V- +1.5V-
    The 1.5 volt battery "boosts" the 12 volt battery, resulting
    in 13.5 volts across Rload
    The terms "buck" and "boost" are most often associated with
    DC to DC converters.
    In the real world circuits the "bucking" or "boosting" is not
    done with batteries. Generally speaking, a voltage is created
    in a coil, and the coil is electronically switched so that the
    voltage in it either adds to ("boosts") the input voltage or
    opposes ("bucks") the input voltage.
    Ed
