I have a 20 watt transistor that is in a device using a 12 volt dc supply. Using 12 volts its output is about 12 watts. I need the output to be in the 16 to 18 watt range looking at specs on this transister 16 volts will give me 20 watts. I do not want to redesign this power suply. Is there any way to use diodes in series to boost 12 volts to about 15 volts. I need a solution that will fit inside this radio can be hooked up as a seprate board so as not to interfere with the rest of the other devices.
Categories
Platforms
Content
