C
Chris Jones
Hi, Anyone have any clues on judging voids in solder joints for cyclic
high pressure applications(0 -350 bar, 0-5000 PSI)? More specific how
would a 0.1mm3 gas pocket under a D2pack on FR4 laminate with 135u
copper layer affect that solder joint if environmental pressure is
cycled between 0 and 350 bar?
Best regards,
Rune
To prevent voids in our compounds wrapped around electronics, we used to
epoxy them in low atmospheric pressure, 10-3 torr [approx Bell Jar]
where we would watch with surprise at how they foamed like crazy before
settling down.
Perhaps, the soldering should be done in rarified atmosphere also, then
your question would become a moot point.
I think you would only really be sure to have no voids if, after
potting/soldering under vacuum, you then let the air back in whilst the
solder / potting compound / whatever is still molten (liquid).
When you make a vacuum around a liquid and it froths as lots of air
comes out, some of the last few bubbles don't always pop. There is very
little air/gas still inside the bubbles, (depending on surface tension
of the bubble and how good your vacuum is), but the bubble is still
there and it still doesn't have the potting compound / solder in it.
Such bubbles full of vacuum could still cause you problems later, if you
let the potting compound / solder solidify whilst still under vacuum. In
the case of potted high voltage assemblies, bubbles full of rough vacuum
probably break down at least as easily as air does, and in the case of
solder, voids full of vacuum will still allow stresses to occur when the
space around your assembly is highly pressurised.
Therefore, if the vacuum soldering is to help, the vacuum would have to
be released just after the peak temperature is reached and the solder
has all reflowed, but before the solder has solidified.
Chris
