A
Angus Thomson
I am using an ST VN05N high side driver to switch power to a Mini-ITX
motherboard (small form factor, low power consumption). The board draws a
maximum of 6A with a hard-drive connected but approx. 4A the rest of the
time; however, the HSD gets very hot within 30secs and then cuts out
momentarily (presumably due to the over-temp protection). The device is
rated for 13A constant current (according to
http://www.st.com/stonline/books/pdf/docs/1082.pdf); am I missing something
obvious here?! It is running in a car, so the supply is around 13V. I'd
really appreciate some help with this; either I'm being stupid (not the
first time), or I have 3 faulty parts (I have tried the same setup with 3
devices with the same result).
Thanks in advance!
Angus Thomson
Thanks in advance!
Angus Thomson
