Vizio TV fix help
pday13
Jun 12, 2013
Jun 12, 2013
Hi I am new to this forum and I am hoping someone here knows TVs well enough to help me out. The TV's model number is VW46L FHDTV20A. The problem is when I turn the TV on it works just fine for a while and then while I am watching it the left half of the screen randomly gets really dark and this bleeds from right to left on the screen. The problem is mostly absent from the right side of the screen and the very top. I have attached some images of what it looks like when this happens.
I am hoping that someone can tell me the problem and the steps that should be taken to fix it ( I have no problem with opening it up and replacing any component that needs to be replaced as it is out of warranty). Thank you for your help.
davenn
14,260
14,260
Hi pday
welcome to the forums :)
this seems to be a pretty common problem with that TV
doing a google search on your model number came upw ith many hits
I suggest you do the same and start reading through them and see if a cure was discovered :)
pday13
Jun 12, 2013
Jun 12, 2013
Hi paddy
Thank you very much for the welcome; I have been scouring the internet and the problem appears to be that the LCD panel is bad (diagnosed by the fact that the problem goes away when pressure is applied to the side). Do you know of any website that may have a replacement panel for sale? I have looked everywhere online and can not find one.
davenn
14,260
14,260
no I dont, sorry
the manufacturer or authorised service centre would probably be your only choices
it is unlikely to be worth it anyway as a replacement panel is likely to cost lots more than a replacement TV
cheers
