Vintage CD Player optical laser pickup
Discussion in 'Electronic Repair' started by Bernardo, Jul 24, 2008.
  1. Bernardo
    Bernardo Guest
    Hello Everybody!!!
    Well I really need your help now. I just got an old NEC CD-510BU CD
    Player, but somebody removed its laser pickup, and I have no idea
    which pickup it uses. I have tried contacting NEC but they did not
    help.
    Well, but I do have some clues: First, manufacturing date of this
    player is april 1987. Also, the connectors for the laser assembly are
    just like KSS-210: a pair of red and white connectors, 8 pin each.
    But, a KSS-210 wont work mechanicaly: The KSS-210 expects the gear for
    the tracking mechanism to be located on the upper side of the CD
    loading mechanism, but this CD Player has the tracking gear located on
    the underside of the loading mechanism. So, a KSS-210 would fit but
    wouldnt move, obviously. Also, by looking at the grease pattern at the
    tracking gear I can tell that the optical pickup that was here before
    uses those two teeth strings connected with a spring, engaged on the
    tracking gear to move.
    Well, that is all I know. I really appreciate ANY feedback as I tried
    everything I could but could not find the part number of the pickup
    this player uses.
    Thank you very much!
    Cheers,
    Bernardo Santos.
  2. hr(bob)
    hr(bob) Guest
    I think you had better resign yourself to throwing it out..
  3. Bernardo
    Bernardo Guest
    I'm afraid so, although I still have some hope I'll fix this thing.
  4. Guest
    Hi
    It is doris here
    we mainly supply many kinds of IC(TEA6842, 70055AB, PCF7935AS....) and
    laser pickup such as SF-DS20, SF-DV21, TOP-1200, SF-HD62, SF-HD6,
    PVR-802W, PVR-502W,SF-HD80, KSS-240A, KHM-240AAA,VED0440, DAX-23E, SF-
    HD4, SF-C93, CDM 12.4.....use for CD, VCD, DVD player, PS2/3, laptop,
    AUTO...
    please contact me if you have any other part to need,we will try to
    meet you
    have a good day
    Best Regards
    Doris.sale
    Dorasami-tech LTD
    Tel: 86-755-82515817
    Fax: 86-755-83612337
    MSN:
    Email:
