R
Ray Carlsen
This Model VCDTS21420 Chassis 19VS002 VGA monitor has HV and the CRT fils are
lit, but there is no H sweep, just a vertical line if G2 is turned up. Q550
(yoke drive?) checks OK but has no B+ on it. Where does the sweep circuit get
it's source voltage? So far, I found bad crimp connections (I soldered them) on
the 2 pin plug of a coil that's wired in series with the yoke and sits on top of
it. I suspect the intermittant plug pins caused the sweep failure and that it's
a common problem in this model. A web search didn't help much. Can you? Thanks
in advance!
Ray Carlsen
A/V Engineering
University of Washington, Seattle
in advance!
Ray Carlsen
A/V Engineering
