________________
This a general suggestion for anyone owning or desiring to own an LCD
flat monitor, including James:
The following suggestions may seem valid only for traditional CRT
monitors & TVs, but heat is heat, and brighter generates more of the
same.
1. Where are your brightness/contrast settings? If they look
something like this:
Min.IIIIIIIIIIIIIIIIII Max,
TURN THEM DOWN!! I usually keep my Brightness at the middle, and my
contrast a little higher.
2. Explore your color driver section. Some mfgs crank their R, G, B
drives to the max. If this is your case, pull them all back to about
the middle. If one is more than the other, pull them all back in the
same ratio. IE:
R Min.IIIIIIIIIIIIIIIII Max.
G Min.IIIIIIIIIIIIII Max.
B Min.IIIIIIIIIIIIII Max.
Pull them back as follows:
R Min.IIIIIIIIII Max.
G Min.IIIIIIIII Max.
B Min.IIIIIIIII Max.
(All of the above depends on your specific menus of course!)
3. If you have a "Color Temperature" menu option, set it to 6500K
instead of 8000 or whatever the higher(hotter) setting is. Although
if you adjust #1 and #2 individually, Color Temp may display "USER"
which is fine.
All of this will have the effect of a deeper, richer image. It WILL
seem darker to you at first, but remember, "Brighter ain't always
better".
What you will be seeing is more representative of real life. IE if
your wallpaper is a baseball stadium at night, it should LOOK like a
stadium at night, not like a stadium at twilight.
The sky over
NYC should be a rich light blue, not whiteish turquoise, and any
shadows on the buildings's setbacks should be a dark gray, not ashen.
If you are watching a DVD, the image should convey *most* of the
director's intentions.
Finally, it will also add significantly to the life of your monitor,
whether CRT, Plasma, or LCD.
regards,
CC
