Viewsonic monitor red
S
Sarah
Hi, I have a Viewsonic 19 inch SVGA monitor, PS790 model
No. VCDTS21420.
works great but no color red, anyone seen this before?
John Gill
No. VCDTS21420.
The must common faults are of a missing color is:
1. A break in the color video signal wire within the video cable.
This usually occurs near the end that connects to the computer.
Try bending the cable and see if the color comes back.
You can purchase new 15 pin ends at Radio Shack and solder a new
end on the cable.
2. A bad solder connection at the socket where the CRT circuit board
plugs onto the back of the picture tube. Just resolder the connections.
3. A bad video driver transistor or driver IC that supplies the color
signals to the picture tube. Measure the voltages on the three color
signal connections on the picture tube socket. The missing one will
usually be very different.
I would download a standard color bar program from the web to determine
which color is actually missing. There are also pinouts on the web that
indicate which pins do what functions on the picture tube socket.
Hope this helps...
John
B
Bob Horvath
end on the cable.
Hope this helps...
John
BTW John,
No. 2 is the exact problem I had with my daughters Gateway
monitor. No blue.
