Video through RF cable no longer works
B
Bozlo
Hey,
We had a pretty strong thunderstorm recently, and one really close
lightning strike. And no longer does the television video work through
the RF cable. I tried putting it directly to the tv, to no avail. So
now I have it going into the vcr and video/audio out to the tv. In
other words video still works fine on the tv, just not through RF
cable. I am guessing the lightning fried something. It is a JVC 36" tv
(CRT), attached to a base, so not easy to move. My question is how
easy, or not would it be to fix, and what would it cost? Thanks very
much!
K
Ken Weitzel
Bozlo said:
Hey,
much!
Hi Bozlo...
Got me confused already, and I expect the others will be
too... :)
Video through the rf cable? Can you explain that differently,
or perhaps in more detail?
Take care.
Ken
i assume he means the 75 ohm cable that comes from the cable company
then out of his vcr
its a real bummer if you have pip and it has to be air/cable or video
in
i prefer video in cause i got the diewrecktv
do you just get the fuzz on channel 3 even with your vcr on and tv
video set to video?
is there any settings in the tv like air/cable or any other switches
or menus
B
Bozlo
then out of his vcr
in
video set to video?
or menus
Yup, RF as in seen here: http://www.hardwaresecrets.com/article/157/2.
This tv doesn't have PIP, so no worries there. When the RF cable is in,
direct to the tv, or via the VCR, it is a black screen, and the channel
numbers show up, as does the audio that accompanies the respective
channel. I suppose I should have mentioned that. I tried rescanning for
channels, and it just brings them back with audio. This is the old
style tv, the cable comes from outside, from the cable company as you
said, and to the vcr/tv.
Using the tv with video output (composite) from the VCR is just fine
for now, but eventually maybe it would be worth fixing, as nothing else
is wrong with the TV. Unless it would cost too much, since CRT TVs are
going the way of the Dodo. Thanks again!
James Thompson
Bozlo said:
Hey,
much!
The tuner module has been zapped, You will have to have a tv service tech
repair that as it is not a user repair job. You are lucky in that it didn't
zap the whole set, but still the repair will not be cheap.
Can't guess on cost for your area, but you can figure at least 100.00 Us
dollars to fix.
T
tomh
hmmm sounds like the video detector or buffer or something in that area
is blown. If you change channels and get the correct sound for each
channel that says the tuner, IF, and Audio det are OK. It's a little
weird that just the video is gone as those things are usually all in the
same IC. Perhaps it's a buffer external to the Video but before the
switch that selects tuner or composite. It could be a simple repair or
not depending on the set is done.
Personally I'd do the cable to VCR composite to TV setup.
