Video Switcher
Discussion in 'General Electronics Discussion' started by georgelawshe, Feb 18, 2012.
  1. georgelawshe
    georgelawshe
    Feb 18, 2012
    I have two Video Inputs to a single output. I would like a swicher that would constantly switch between the two inputs with adjustable preset "ON" times.
    Camera A would be on for 3 minutes then Camera B would be on for 5 Minutes then loop again.
    I would like the adjustable times to be from 2 to 8 minutes.
    Any ideas? Your help will be appreciated.
    GeorgeLawshe
  2. twister
    twister
    172
    7
    Feb 12, 2012
    I think a 556 set up as two monostable circuits would work. The outputs could control a relay or transistor to turn on and off your cameras. You would feed back the outputs to the trigger or the opposite timer. I don't know how to draw schematics on the computer but maybe someone else could draw it for you. You would need two variable pots for R1.
  3. georgelawshe
    georgelawshe
    Feb 18, 2012
    This is my problem, I can build the circuit with no problem, my problem is designing the circuit, Can anyone help with this?
    GeorgeLawshe
  4. twister
    twister
    172
    7
    Feb 12, 2012
    Sorry that my first link didn't work.
    http://www.kpsec.freeuk.com/555timer.htm
    Maybe if you study the 555 circuits you can figure out how to make a circuit work for you. If you go to an electronic supplier you can get a breadboard that will allow you to plug in components to test out your theorys. It is always best to breadboard a new circuit to see if it will work. I buy a lot of stuff from Jameco.com and they seem to have good prices.
