Video card repair , please help
Discussion in 'Troubleshooting and Repair' started by Cqzi, Nov 24, 2017.
  1. Cqzi
    Cqzi
    6
    Nov 24, 2017
    Hello guys , after searching all the internet about if it's posible to repair my videocard who does't work at all , tried different things in software but nothing works (old and new driver , old and new windows) , the card has something thats for sure . I buyed the card broken very cheap , hoping i can fix it (goddamit i was wrong) because i really dont have money for an acceptable gaming card . I dont know if i am in the right place to ask for help with my videocard but i am really desperate .
    So, the card is Gtx titan 6gb (2013) refference and this is the error : https://s18.postimg.org/udiavw6g9/Untitled.png
    This is the card itself : https://postimg.org/gallery/1apyruauu/
    I was reading something about put the videocard in a microwave but no thanks, rofl , but something pop out, someguy with multimeter veryfing sum motherboard capacitors/mosfets etc . and i said to myself "maybe i can buy one cheap multimeter and hope its something replaceble in the videocard itself?" i dont know much about electrics but i am really want to know more . And before spending more money on the multimeter and orther stupid ideas , can you guys advice me what can i do ?
  2. kellys_eye
    kellys_eye
    4,282
    1,152
    Jun 25, 2010
    Your screen cap shows that you have the card fitted and, seemingly, working..... how else would you have a screen display otherwise?
    The alternative is that you've fitted the card but you've not disabled the built-in graphics so the PC isn't able to access it.
    But purchasing a known, non-working, graphics card is stupidity of the first order - and considering you have zero skills to find/repair such a device (difficult/impossible for even the most skilful engineer) only compounds the issue.
    I'd put this down to experience and throw it away (assuming the above comment on disabling the built-in graphics doesn't make any difference).
    Cqzi likes this.
  3. Cqzi
    Cqzi
    6
    Nov 24, 2017
    The integrated graphic card was disabled , and with the dvi in the videocard itself it gives image with microsoft display driver but not showing in the entire monitor and it was on full resolution and when i instaled nvidia driver just black image ( once gave me pink with lines image for couple of seconds) . I know i made a bad decision buying this , i realise after i buyed , never again .
  4. Cqzi
    Cqzi
    6
    Nov 24, 2017
    If its a way i can find where is the problem , what is broken or any suggestion , i am open to try it ;)
  5. kellys_eye
    kellys_eye
    4,282
    1,152
    Jun 25, 2010
    Change all the electrolytic capacitors. If no better then change the GPU.....
    Without a schematic and a Digital Storage Oscilloscope you are left with 'grasping straws' hence the suggestion above.
    All parts are surface-mounted so expect difficulties in removing replacing the capacitors and zero success changing the GPU......
    davenn likes this.
  6. Cqzi
    Cqzi
    6
    Nov 24, 2017
    Lets say i will find a bad capacitor or a bad mosfet how do i know what type of capacitor/mosfet works on the graphic card , there are 2 type of capacitor on this card : "A3 OCRZ 270 16V" and A3 560 2.5Z and mosfet (i think so , the one between memory and vrm) "330 2ncpxe"
  7. kellys_eye
    kellys_eye
    4,282
    1,152
    Jun 25, 2010
    You replace parts on a like-for-like basis, Googling the parts to source replacements. As long as the value and voltage match the part will work - even if it's physically different in appearance.
    If you have broken MOSFETs then the chances of repair are even lower. As already mentioned, without a schematic you're on your own.
  8. Cqzi
    Cqzi
    6
    Nov 24, 2017
    So is imposible to find a schematic for this card , right ?
    "If you have broken MOSFETs then the chances of repair are even lower" why is that ? Because its dificult to replace the mosfet or is dificult to find the same one ?
  9. kellys_eye
    kellys_eye
    4,282
    1,152
    Jun 25, 2010
    ...as good as. The manufacturers MIGHT give you a copy but you'd probably be the first person ever to get one!
    More because mosfets don't blow for no reason - there is usually another cause for their demise and that only leads to having to trace the circuit(ry). Being a multi-layered pcb the chances of doing that are under 2%.
  10. Cqzi
    Cqzi
    6
    Nov 24, 2017
    Ok ... i decide to let it go , i dont wanna spend more money on this crap , i will save money and i will buy a new one ... thanks for everything mate
    davenn likes this.
