Video buffer amp
Discussion in 'Electronic Basics' started by Data888, Sep 18, 2003.
  1. Data888
    Data888 Guest
    I'm not sure if any of you remember but I've posted some questions about
    building a video switcher. I found this schematic for a buffer amplifier
    to put on the output:
    http://www.mopacmedia.com/tips/pxlmod3.html
    Is this suitable? I don't understand much about transistors but if the
    amplifier is running off 9v, won't the output be peaking at 9v? I
    thought a video signal was 1V p-p.
    Can anyone answer there questions for me? Thanks.
    Nick
  2. That is a simple emitter follower, which will have a gain of 1 (pretty
    closely) - if you feed a 1V P-P video signal into it, you will get 1V
    P-P out.
  3. The OP doesn't say if he wants to drive a cable. The buffer doesn't
    account for the driving impedance of the cable and the gain of 2
    needed to accomplish it. Also, most video has sync negative (back
    porch at 0 v) and the buffer with its ground reference can't go
    negative and throws in a negative offset to boot. If the buffer is
    used internally on a circuit board it could be usable.
    GG
  4. Baphomet
    Baphomet Guest
    snip... snip...
    Putting a clamping diode (cathode to transistor base - anode to ground)
    should solve the problem (I think) of the negative sync.
  5. You mean as a 'catch' diode to clamp the sync tip?. That helps with
    the clipping but does not deal with the necessary DC offset. The real
    problem is to provide current boost, preferably with no DC offset,
    possible gain of 2, possible 75 ohm line drive (very low source
    impedance with proper resistor). My personal favorite is to use
    current feedback amps with bipolar supplies and DC coupling. DC
    restoration if that parameter is important. Yeah, I know it costs more
    but I'm using several hundred dollars of computer and an extra few
    bucks doesn't seem that prohibitive to me-- particularly if it works
    great and I can forget about it and just use it. Sorry to ramble.
    GG
