mikewilder
- May 26, 2012
- 2
- Joined
- May 26, 2012
- Messages
- 2
Sounds dumb, but has anyone tried to place composite video on the same cable with rf (cable co) and then seperate it back out at the television? I have a situation where the house is already wired and finished. We originally had or security cameras modulated to channel 116 and placed into the dist. amp with the analog cable. Now the cable co has updated the system to a digital format with set top boxes. If I could get composite to the tv, I could have the customer switch to video input to view the cameras.
The only other solution that I can come up with is to use a wireless transmitter and receiver pair.
Again, this sounds dumb. I think it should work, the two signals are different enough that they shouldn't bother each other. Video is 0-4.5 mhz and the cable is somewhere in the 400mhz range. It would help me to know if this has been tried.
Thanks in advance for the answer.
