vibration motor
Discussion in 'Sensors and Actuators' started by shelby, Mar 7, 2012.
  1. shelby
    shelby
    7
    Mar 7, 2012
    Anyone know how to get a 7-segment display to work with a vibration motor.
    So say the 7-segment display says '3'
    how do i get the vibration motor to vibrate the number of times displayed on the 7-segment display?
  2. (*steve*)
    25,401
    2,777
    You're not going to get a simple answer.
    Perhaps the easiest way is to use a microcontroller, but the problem then becomes -- how does it know that the number 3 is on the display?
    Can the circuit be changed so that the display driver is replaced by something a little more clever? How well do you know how the original works?
  3. jackorocko
    jackorocko
    1,284
    Apr 4, 2010
    the easiest way is to have the seven segment display be populated by the micro-controller. You must have something that can relate the two circuits.
  4. Rleo6965
    Rleo6965
    585
    9
    Jan 22, 2012
    You have to build a circuit that can convert the binary code input of 7 segment display controller. Then this circuit will also give signal pulse output to the control motor.
  5. shelby
    shelby
    7
    Mar 7, 2012
    Is there a way of using frequencies to make a vibration motor, give signals like mos code?
    Maybe converting the 7 segment display, into vibrations. so Display: 3 = 3 small vibrations.
  6. davenn
    davenn Moderator
    13,598
    1,875
    As Steve said its going to take some microprocessor control.
    So as the processor is sending the "signals" to the 7 seg display out of one set of ports
    it will also be sending a signal out of another port to the vibrating motor
  7. shelby
    shelby
    7
    Mar 7, 2012
    no doubt about it, I'll most likely use a C programme to perform tasks according to the 7-segment display.
