New to the forum here. Hope Im posting to the right area. I am a runner and try to follow a 180 SPM run cadence. I want to design a vibrating metronome that will fit into the casing of a watch to be worn while running and not disturb other runners with an annoying beep. I have been doing some research and am not sure if this project will be possible. I am thinking if it is possible I would use a 555 IC. I would also like to keep a small battery (possibly 3v) that will fit inside the case of a watch. Im not sure if this will be possible due to the current requirements of a vibrating motor.
If anyone could guide me in the right direction of how to figure this circuit out or if its even possible that would be great!
