vibrating DC motor
Discussion in 'Electrical Engineering' started by Guy S., Dec 14, 2005.
  1. Guy S.
    Guy S. Guest
    I just bought a 1/2 hp dc motor to replaced a smaller one
    who was working well except it overheated after a while.
    the motor is driven by a KB scr drive.
    When free running everything seem well, it vibrate on start but pick up
    its speed and is eventually humming.
    when the work load is attached, there is a strong vibration shaking
    the whole thing.
    no matter what speed the pot is ajusted, it ring loudly.
    i tried another drive, also SCR drive, from another manufacturer and it
    seem even worst.
    i took the motor to the repair shop they put it on a test and
    everything is ok,
    they say there must be a match between some motor and some scr drives.
    well how to do that?
    i would like better to understand what is going on anr fis the mismatch
    by adding perhaps a condenser or a choke or a combination or modifying
    the brushes or what....
    can some one help me on this one?
  2. This is going to be a tough one to diagnose over the usenet.
    Its possible that the new, larger motor is stiffer, from a control
    systems point of view. The interaction between the speed control drive,
    the motor and the mechanical load might be operating nearer a resonant
    point.
  3. not i
    not i Guest
    Check the IR compensation setting on the controller.
