rob_croxford
- Aug 3, 2010
- 262
- Joined
- Aug 3, 2010
- Messages
- 262
Hi All,
I have recently been trying to get into VHDL coding for use on FPGA's. I have been designing an Encoder/Decoder type system for error coding.
I have a question which i hope someone will be able to shed some light on:
I have designed a 7/4 decoder and a 15/11 decoder however i wish to make this code generic in that it the single piece of code will work for both designs.
any help or pointers would be greatly appreciated.
code bellow: (7-4 decoder can also send 15/11 decoder if needed)
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.STD_LOGIC_UNSIGNED.all;
ENTITY decoder IS
PORT (clk : IN STD_LOGIC;
res : IN STD_LOGIC;
sin : IN STD_LOGIC;
dout : OUT STD_LOGIC_VECTOR(3 downto 0));
END decoder;
ARCHITECTURE behaviour OF decoder IS
SIGNAL control : STD_LOGIC_VECTOR(6 downto 0);
SIGNAL rxlss : STD_LOGIC_VECTOR(3 downto 1);
SIGNAL sipo : STD_LOGIC_VECTOR(6 downto 0);
SIGNAL error : STD_LOGIC_VECTOR(2 downto 0);
BEGIN
error <= sipo(6 downto 4);
PROCESS
BEGIN
WAIT UNTIL RISING_EDGE (clk);
IF(res = '1') THEN
control <= "1000000";
rxlss <= "000";
sipo <= "0000000";
ELSIF(res = '0') THEN
rxlss(1) <= (sin XOR rxlss(3) XOR rxlss(2)) AND NOT(control(0));
rxlss(2) <= rxlss(1) AND NOT(control(0));
rxlss(3) <= rxlss(2) AND NOT(control(0));
sipo <= (sin XOR rxlss(3) XOR rxlss(2)) & sipo(6 downto 1);
IF control(6) = '1' THEN
CASE (error) is
WHEN "001" => dout <= (sipo(3 downto 0)) XOR ("1101");
WHEN "011" => dout <= (sipo(3 downto 0)) XOR ("1010");
WHEN "111" => dout <= (sipo(3 downto 0)) XOR ("0100");
WHEN "110" => dout <= (sipo(3 downto 0)) XOR ("1000");
WHEN OTHERS => dout <= sipo(3 downto 0);
END CASE;
END IF;
control(6 downto 0) <= (control(0)) & (control(6 downto 1));
END IF;
END PROCESS;
END behaviour;
Best regards,
Rob
library IEEE;
ENTITY decoder IS
res : IN STD_LOGIC;
sin : IN STD_LOGIC;
END decoder;
BEGIN
PROCESS
BEGIN
IF(res = '1') THEN
rxlss <= "000";
sipo <= "0000000";
CASE (error) is
END CASE;
END IF;
END IF;
END PROCESS;
END behaviour;
Best regards,
Rob
