Very Unusual Memory Card Problem
Discussion in 'Electronic Repair' started by [email protected], Jun 4, 2005.
  1. Guest
    I hope someone can help me and If not maybe point me in the right
    direction.
    I have a slimline ps2 as well as a old model ps2.I can't save God Of
    War or Area 51 on the slimline machine.I can save as well as load both
    games on my older model on the same memory cards that don't work on the
    slimline.Actually,the slimline will load both of those games fine.But
    when I try to save it says save failed,then acts like it can't see my
    memory card.I can save various other games on the slimline with no
    problems.I can open my memory card in the explorer and see all my saved
    files.The cards work fine on the older system.I loaded up my God Of War
    Save on the slimline.It works.But when I try to step right back into
    the save and save it says "Error Saving Data"I am really stumped on
    this one.Please help or direct me.I appreciate your time and thank you
    in advance
  2. nvic
    nvic Guest
    I have heard of games that were not compatible with the slimline. If
    you can still load, the game might not be designed for that ps2. It is
    mainly those big games, you know the ones with really good graphix and
    lots of sound. It may be too much for the little ps2. I have heard the
    little ps2's have less internal memory for running games, mainly for
    space. I have one question, can you save the game if you don't let a
    level load before saving? (Load, don't load a level, and save) If so,
    the incompatibility may be the problem. Let me know, nvic.
  3. nvic
    nvic Guest
    I have heard of games that were not comppatible with the slimlines. If
    the incompatiblity may be the problem. Let me know, nvic.
  4. paul405
    paul405 Guest
    hi there
    not heard of this one before , however i have heard of the memory
    allocation being in a different place , and therefore when you go to
    replace the info part of the memory dump into the machine , it can only
    put half or so back in to the correct address .and hence an incomplete
    program is dumpled .when read it is read with errors .
    de paul
