Very simple switch/inputs help
Discussion in 'Microcontrollers, Programming and IoT' started by Photon, Nov 16, 2015.
  1. Photon
    Photon
    16
    Nov 1, 2015
    Hello again
    I have few ATmega 8 and 328 chips with external oscillators 16KHz, also an arduino board with the inbuilt 328.
    LavaGuava had attempted helping by writing up a code for me, but ive had issues and want to take different approach at program.
    My goal is to create a program to control a set of power transformers/ relays in a switch formation to car ignition, so that after receiving 3 input pulses of 12v or less it would activate an output (power transformer - relay) to start the engines crank.
    the complex part is the program needs to receive other override signal/sensors that will prevent electrical engine crank depending on their N/O N/C states. example, car gear lever in gear, or handbreak not enguaged. These are simple for me to do, only need help with programming side.
    another input is a 12v supply when the engine is running to kill the start/procedure so it dosent grind the starter cogs. finding and identifying these wires i will also easily do, just need help finding where they come into the circuit.
    Before i posted this thread, id drawn up some complicated relay/ transistor switch schematics but failed. this seems like a simple circuit to design but my electronics is rusty after 3 years away from.
    Any help really appreciated
  2. Photon
    Photon
    16
    Nov 1, 2015
    this internet thing is so ridiculous
  3. davenn
    davenn Moderator
    13,785
    1,936
    what's the reason ?
  4. Photon
    Photon
    16
    Nov 1, 2015
    I wish I knew
