Very Simple Circuit but cannot work! Please help.
JayJoe
Jul 31, 2015
12
Jul 31, 2015
12
void initiate_main()
trisa=1; porta=0;
trisd=0; portd=0;
void main()
initiate_main();
while(1)
if(porta.f0==1)
portd.f0=1;
else
portd.f0=0;
What's wrong with the programming?
Harald Kapp
13,700
13,700
portd.f0 = 0 or 1, but the LED is on portb.
Either change the HW port of the assignment in the SW.
JayJoe
Jul 31, 2015
12
Jul 31, 2015
12
oh, i uploaded the wrong picture. anyway, stick with this circuit ive uploaded, even ive change the programming code to port b, it still doesnt work!
Harald Kapp
13,700
13,700
The programming seems o.k.
Is the oscillator running? Is the power supply o.k.? Is the LED in the correct orientation (short leg = cathode to ground)?
JayJoe
Jul 31, 2015
12
Jul 31, 2015
12
Ive found the answer. Port A cannot be input. It turns out working when i use port D as input. can anybody tell me why?
JayJoe
Jul 31, 2015
12
Jul 31, 2015
12
Hmm. I am thinking the same too, but it works using port d instead of port a. Still wondering.
Sorry that i'm still new to PIC, thanks for your reply.
Anyway, may i know the word 'TRIS' stands for?
CDRIVE
Hauling 10' pipe on a Trek Shift3
May 8, 2012
4,960
May 8, 2012
4,960
I believe it means "Tri-State" Register. IE a port that can have one of 3 states. High (5V), Low(0V) or Open(Hi Z).
Chris
davenn
14,254
14,254
from this www site ..... http://www.mikroe.com/chapters/view/16/chapter-3-pic16f887-microcontroller/
3.3 INPUT/OUTPUT PORTS
In order to synchronize the operation of I/O ports with the internal 8-bit organization of the microcontroller, they are, similar to registers, grouped into five ports denoted by A, B, C, D and E. All of them have several features in common:
  • For practical reasons, many I/O pins are multifunctional. If a pin performs any of these functions, it may not be used as a general-purpose input/output pin.
  • Every port has its ‘satellite’, i.e. the corresponding TRIS register: TRISA, TRISB, TRISC etc. which determines the performance of port bits, but not their contents.
By clearing any bit of the TRIS register (bit=0), the corresponding port pin is configured as an output. Similarly, by setting any bit of the TRIS register (bit=1), the corresponding port pin is configured as an input. This rule is easy to remember 0 = Output, 1 = Input.
PORTA and TRISA register
Port A is an 8-bit wide, bidirectional port. Bits of the TRISA and ANSEL registers control the Port A pins. All Port A pins act as digital inputs/outputs. Five of them can also be analog inputs (denoted by AN):
CDRIVE
May 8, 2012
4,960
May 8, 2012
4,960
I love the graphics on the MikroElectronika website.
Chris
JayJoe
Jul 31, 2015
12
Jul 31, 2015
12
Chris
Oh, tri-state. Thanks. May I know what do you mean by 'Open(Hi Z)'?
JayJoe
Jul 31, 2015
12
Jul 31, 2015
12
Great. Now I understand better. Thanks for the website davenn! :)
jayanthd
Jul 4, 2015
43
Jul 4, 2015
43
Try this code in your mikroC PRO PIC Compiler and it will work. If you have used 4 MHz crystal then select XT for Oscillator typr in edit project dialog box else choose HS.
Code:
    cmcon = 7;
    cvrcon = 0;
    adcon1 = 0x87;
    trisa = 1;
    porta = 0;
void main()
    initiate_main();
    delay_ms(200);
    while(1)
        if(porta.f0 == 1)
            delay_ms(50);
            if(porta.f0 == 1)
                portd.f0 = 1;
        else if(porta.f0 == 0)
            delay_ms(50);
            if(porta.f0 == 0)
                portd.f0 = 0;
