Very high input impedance high voltage meter???
Discussion in 'Electronic Repair' started by Norm Dresner, Sep 17, 2004.
  1. Norm Dresner
    Norm Dresner Guest
    I could also do the same thing with a pair of pots. The advantage of the
    dual caps from a factory-built oscillator is that the hard mechanical work
    is all done -- and they're presumably matched well enough. It's simply less
    work. BTW, it's a lot easier to get 10-turn pots than even one-turn
    capacitors these days..
    Norm
  2. James Sweet
    James Sweet Guest
    Yeah, just thought there might be some particular reason you needed variable
    caps.
