very basic doorbell
Discussion in 'Electronic Design' started by [email protected], Sep 24, 2007.
  1. Guest
    Hi all,
    I'm designing a very simple doorbell circuit. I am very new to
    electronics, so I'd really like to verify my idea with someone.
    I'll get a 10mA, 12 volt piezo buzzer from Radio Shack and plan on
    running a 12 volt battery in series with a 1200 ohm resistor to the
    buzzer from a push button.
    I'm using 1200 ohm resistor based on R = V / I, that is 12
    volts / .01 amps = 1200 ohms.
    I have a paranoia about starting a fire -- under what conditions,
    if any, could a circuit like this start a fire?
    Thanks so much if anyone wants to indulge in such an elementary
    post....
  2. That likely means it uses 10mA when it is connected to 12 V.
    You do not need and do not want the resistor.
    The thing itself is about 1200Ohm
    and plan on
    A battery with enough Ah and a low enough Ri together with a short in the
    buzzer *could* do it.
    If you are paranoid use a 50mA fuse in series.
  3. Guest
    thanks for the response. I just realized I should have posted in
    sci.electronics.basics - sorry about that.
  4. Tam/WB2TT
    Tam/WB2TT Guest
    What you calculated is the total resistance; that is the value of the
    external resistor, plus the resistance of the buzzer As somebody poined out,
    the buzzer is probably about 1200 Ohms by itself. That would be how they got
    the 10 ma.
    Tam
  5. Guest
    cool - got it.
    One more question, how is a 50mA fuse determined? That is, why a 50mA,
    not 40, etc.
    thanks a lot...
  6. The fuse value is not particularly critical - you want it large enough
    that the fuse will not blow during normal operation, but small enough
    that a true fault will blow it. You also want a
    commercially-available value, which may be why 50 mA was suggested,
    rather than 40 mA.
    Peter Bennett, VE7CEI
    peterbb4 (at) interchange.ubc.ca
    new newsgroup users info : http://vancouver-webpages.com/nnq
    GPS and NMEA info: http://vancouver-webpages.com/peter
    Vancouver Power Squadron: http://vancouver.powersquadron.ca
  7. neon
    neon
    1,325
    Oct 21, 2006
    POWER is the key 12v and 50ma is nothing. the transformer will open up with a short and that is the wost case scenario.
  8. Rich Grise
    Rich Grise Guest
    Apology accepted. :)
    Everybody makes mistakes - that's how we learn stuff.
    Cheers!
    Rich
