Vertical Stripes on SAMSUNG 520 TFT
Discussion in 'Electronic Repair' started by [email protected], Apr 22, 2007.
  1. Guest
  2. Franc Zabkar
    Franc Zabkar Guest
    It looks like some sort of addressing issue. Since the good and bad
    bands are of equal width, I'd suspect a fault in the least significant
    bit ... somewhere.
    - Franc Zabkar
  3. Guest
    Hi Franc,
    Thanks for your replay. My level of electronics knowledge is not so
    advanced,
    so I will very much appreciate if you have will and time to explain me
    those things little bit on a 'dummies' level.
    I can read electronic blueprints, I can do Boolean algebra, but I've
    never repaired TV or computer monitor.
    Dusan
  4. Sofie
    Sofie Guest
    Dusan:
    ..... and you are not going to be able to fix this one either, and it is most
    likely NOT economically repairable even by a qualified technician at a
    repair shop given the symptoms you reported. Some problems can make sense
    to repair but not this one.
    Welcome to the world of throw away Chinese electronics.
    Best Regards,
    Daniel Sofie
    Electronics Supply & Repair
  5. Sofie
    Sofie Guest
    Dusan:
    Another thought.... you might want to try another monitor to make sure the
    problem is not your computer's video card.... or try another computer on
    your Samsung monitor to confirm that the problem is actually in the monitor.
    Best Regards
    Daniel Sofie
