Vertical IC Rerplacement
Discussion in 'Datasheets, Manuals and Component Identification' started by Comnics, Jul 27, 2012.
Thread Status:
Not open for further replies.
  1. Comnics
    Comnics
    20
    Feb 12, 2012
    Hi! to All.. i have something to share. i discovered that the 4 vertical IC's with not the same number are the same function.
    UTC78040
    TDA8127
    AN5522
    TDA9302
    i hope this will give help.
  2. GreenGiant
    GreenGiant
    842
    6
    Feb 9, 2012
    While the first and the last are similar form factors and SIMILAR function as far as I can tell they are all totally different
    There are many IC's that have the same function but are made by different companies and therefor have different numbers and possibly different pinouts but these are not
    Do you have the data sheets for them?
  3. Comnics
    Comnics
    20
    Feb 12, 2012
    no need data sheet of that ic's because i've used this 4 kinds of IC's and yes its true different companies and different IC's names but even I cannot believe at first until I proved it to myself.
  4. davenn
    davenn Moderator
    13,865
    1,956
    You are missing the point !! :)
    Yes they are all vertical o-p IC's but they are NOT SWAPPABLE
    They have different pin connections ..... So YES you would need the data sheets
    what you have done is list a bunch of IC's that have the same purpose tho their function is a bit different
    I would be the same as me saying hey I have discovered 4 microprocessor chips...
    a Z80, a MC68000, a 286 and a quad core pentium
    Yup they are all micros, but they have different part numbers and manufacturers and pin outs and they are NOT interchangeable ;)
    What you need to realise in the electronics industry there are many many chips that have the same purpose by different manufacturers but are not pinned the same way :)
    cheers
  5. Comnics
    Comnics
    20
    Feb 12, 2012
    i have a small shop here in PH repairing Computer and Electronics. and i use that ic's in one TV. i pull out first the original Vertical IC and i replace the 3 IC's one by one, and nothing is change, the function is normal, no blown up, and there's no deference in function, that's why i am sure that it is the same in use! i swear!
  6. davenn
    davenn Moderator
    13,865
    1,956
    I looked at the data sheets last nite, they all have different pin outs
  7. Comnics
    Comnics
    20
    Feb 12, 2012
    ok, for me tested and proven.
  8. GreenGiant
    GreenGiant
    842
    6
    Feb 9, 2012
    It seems that the TV in question while you were testing it did not use the section of the board that uses that particular IC for some reason, maybe because it is for a specific input, output, internal function etc.
    These IC's are not the same, in any way other than the footprint, and they cannot be used interchangeably
  9. keciimra
    keciimra
    Dec 28, 2014
    UTC78040, AN5522 and TDA9302 have same pinouts (1-inverting IN, 2-supply, 3-flyback gen, 4-ground, 5-output, 6-output supply, 7-non-invert IN) but the TDA 8127 doesnt seem to have info on the web. Therefore the first three heatsink-mounted vertical ic's are identical but from different manufacturer
  10. Douglas Duran
    Douglas Duran
    Mar 21, 2019
    dO WE HAVE A REPLACEMENT FOR la78141?
  11. Chengkoy1
    Chengkoy1
    Apr 21, 2020
    Replacement of la78141?
  12. Harald Kapp
    11,644
    2,691
    Hijack of old thread, doesn't even match the topic. Thread closed.
Similar Threads
Loading...
Thread Status:
