Verbatim CD-R's are junk!
N
Neil
Hello
For anyone who has burned CD's for Music, or Data, I've found VERBATIM
CD'S are the worst. The average seek time is > 7 seconds for newly
burned discs. I thought I had a problem with my CD-RW Drive, so I
cleaned the optical laser with a cleaning CD, then lightly cleaned it
out with compressed air. I tried other brands from TDK, Maxell,
Imation, CD-R's and they all work fine.
I also looked at the model of my player to make it was MULTI-READ
COMPLIANT, and it is. It appears that the stamped out( bright silver
surface type) CD's from the Software Companies work the best. The
average seek time is less then a couple seconds. These VERBATIM CD-R's,
the surface refectivity is very low, so the laser takes longer for it
to read the CD. If there was a mechanical problem with my drive, it
would of showed up on ALL the discs, not just Verbatim
CD-R's but it doesn't. My friend had the same problem with a burned
CD I gave him from the stack, and he has a Brand new SONY CD_RW/DVD
Writer Drive on his system.
Avoid them like the plague! I'm thinking of dumping these CD-R's and
buying some others to replace them. You might have better luck with
your machine,model,make etc, but I will never buy these again!!
For those who are wondering which ones I'm refering to, on the side of
the blue and white packaging, there is a reorder number# 95028
I wrote Verbatim a Email,I notified them that there could be
manufacturing flaw with the CD-R's I got at christmas.
No Reply!!
-Neil
M
mc
All you know is that they don't work well with *your* CD recorder. Your CD
recorder might be at one end of the range of acceptable parameters, such
that it's completely out of range for Verbatim CDs but not for some others
(they all differ somewhat).
