Velleman Voice Changer Mod
Discussion in 'General Electronics Discussion' started by Rushmoore, Jun 21, 2015.
  1. Rushmoore
    Rushmoore
    26
    Jun 21, 2015
    Hey there!
    Before I begin, I confess that I am an electronics noob and I apologize for asking such stupid questions. Ahem. Ill begin:
    So I want to use the velleman voice changer, the device modifies the speakers voice in real time, however I do not want this. I want to be able to record a message then press a button to hear the modified voice. How can I do this?
  2. Martaine2005
    Martaine2005
    3,670
    1,002
    May 12, 2015
    Hi Rushmore, you should have really bought a voice recorder / module.
    But you can get one of these.
    And use it with your voice changer.
    Martin
  3. Rushmoore
    Rushmoore
    26
    Jun 21, 2015
    Hey, Thanks for this :) Do you know how I could wire up the voice changer with the voice recorder?
    Many Thanks :)
  4. Martaine2005
    Martaine2005
    3,670
    1,002
    May 12, 2015
    Hi, what voice changer kit is it? Was it a kit version?
    Mk171?
    The above voice changer has a speaker output. The other unit I linked to has a line input and speaker output, So shouldn't be a problem getting them to work together.
    Martin
  5. Rushmoore
    Rushmoore
    26
    Jun 21, 2015
    I think Ill use this one: https://www.quasarelectronics.co.uk/Item/velleman-mk195-voice-recorder-playback-kit
    If I use this I won't have to use the voice recorder, it's not really a voice changer, but you can change the speed of the audio, which is fine for my needs. The next problem is that I want to use one speaker with both these devices:
    http://www.amazon.co.uk/dp/B00QIW52...m=A3P5ROKL5A1OLE&pf_rd_r=05W17NVCQZ3H572Q8KFG
    I need to be able to record my voice and also play pre recorded files, so I am going to use those two devices. Is using an amplifier the best way to do this?
    Muchas Gracias
  6. Martaine2005
    Martaine2005
    3,670
    1,002
    May 12, 2015
    The unit I linked to will do exactly what you want. One speaker to both units.
    And also play pre-recorded samples / messages too.
    The cheaper unit doesn't have inputs for pre-recorded files either.
    De nada
    Martin
  7. Rushmoore
    Rushmoore
    26
    Jun 21, 2015
    But this device doesn't let you store multiple sound flies does it? D:
  8. Martaine2005
    Martaine2005
    3,670
    1,002
    May 12, 2015
    Oops, that's very true.
    Hehe,, If you buy that TOO, you'll have all three and be able to do all of it.:D
  9. Rushmoore
    Rushmoore
    26
    Jun 21, 2015
    hehe that is true :D Well, thanks for helping me out :) Tis much appreciated comrade :D
  10. Martaine2005
    Martaine2005
    3,670
    1,002
    May 12, 2015
    No probs
    Martin
