Jack B. Pollack
I am trying to build a project using a CD4051B demultiplexor
(http://www.ee.washington.edu/stores/DataSheets/cd4000/cd4051.pdf). The
output of the chip is fairly inconsistent, some times it outputs other times
it does not. If a wave my had over it sometimes it works. If I ground VEE
sometimes it works. I think my problem is with the VEE pin voltage.
The way I have things wired is as follows:
VDD = +5V
VSS = GND
IHN = L
VEE (see below)
I have tried grounding VEE, grounding it through a 10K resistor, and
grounding it through a small cap. None of these thing made the circuit more
stable.
What do I want to use a VEE? Any other ideas on how to make the circuit more
stable.
VDD = +5V
VSS = GND
IHN = L
VEE (see below)
stable.
stable.
