VCR Not Playing
Discussion in 'Electronic Repair' started by tkbirdie, Feb 7, 2006.
  1. tkbirdie
    tkbirdie Guest
    I put a tape into the VCR and it plays as normal, but is showing no
    images, just black and white lines you get if you play a blank tape.
    There's no sound either. I'm not sure why its doing this. Does it
    need cleaning or is it broken?
    Please help.
  2. JANA
    JANA Guest
    The video head may be badly clogged, or it has failed, or there is some
    other type of failure in the video path, or part of the power supply. You
    can start by having the machine properly cleaned and checked.
    Considering the low cost of VCR's today, it may be more feasible for you to
    consider getting a new VCR, rather than sinking good money in to servicing
    an old one.
    JANA
    _____
    Please help.
  3. b
    b Guest
    is this the same vcr that has been chewing your tapes in your other
    recent post?
    -b
  4. tkbirdie
    tkbirdie Guest
    Yeah, it is. Somehow, it managed to correct itself. I put another
    tape in and it started working fine. I'm not sure why it happened in
    the first place though.
  5. rb
    rb Guest
    Your heads are clogged with bits of tape from when you had the jamming
    problem
