VCLFO debugging
darren adcock
Sep 26, 2016
463
Sep 26, 2016
463
it says the power supply should be 1000ma max, I'm confused why it would have a maximum? is it saying not to pull more than 1000ma through the circuit? or a higher ma rated power supply is bad for it?
kellys_eye
Jun 25, 2010
6,514
Jun 25, 2010
6,514
That's a complete misnomer - providing you have sufficient current to meet that DRAWN from the supply the circuit will work. If you try to draw more than the stated current you will probably overheat the regulator and it will shut down.
73's de Edd
Aug 21, 2015
3,628
Aug 21, 2015
3,628
Sir darren adcock . . . . .
Reading this will fill you in on the complete power supplies aspects, plus the 1000 ma spec was for several units being tied into it, seems like your simple board would only see ~25 ma current pull .
Sooooooo . . . . the shown power supplies degree of Blue prefiltering capacitors are overlill for your meager power needs.
WALL WART POWER SUPPLY REFERENCING:
http://musicfromouterspace.com/analogsynth_new/WALLWARTSUPPLY/WALLWARTSUPPLY.php
Here is a dual polarity PS build schematic :
http://musicfromouterspace.com/analogsynth_new/WALLWARTSUPPLY/schematicpage1_assembly.pdf
73’s de Edd
darren adcock
Sep 26, 2016
463
Sep 26, 2016
463
Thanks Edd. I'll try and understand the source better.
I do intend on supplying multiple in the end. Do I just make sure after adding up the current draw off each unit it doesn't exceed the supply current?
