Bodgerbill
- Mar 3, 2020
- 2
- Joined
- Mar 3, 2020
- Messages
- 2
Hi all,
I have a Frequency Counter VC3165 which has partially failed. It has different modes it operates in controlled by 3 front panel buttons but the buttons no longer work so its stuck on reading frequency in mode 1 (50MHz-2.4GHz). It displays the input signal frequency ok and there is only an Ic2 connection between the main microcontroller and display driver so I figure the main microcontroller in it is working fine and the display driver is also working mostly.
Please see attached schematic...
The display driver it uses is a ZLG7289A chip which appears to be a I2C to 8 common cathode 7 segment display driver and button multiplexor. As the frequency display is working fine, but the buttons are not being read, then I figure the problem is with this chip.
This chip has original markings indicating that it is a PIC16C55 microcontroller that is preprogrammed for a specific application and marketed as a ZLG7289A. I dont' have a programmer for this chip nor the source code to program another.
This Frequency counter seems to be common and has been marketed under different brand names. (I have checked all solder joints etc on the board by the way and do not think the problem is a physical one!)
So I am trying to source a replacment ZLG7289A part for it. I have found Chinese datasheets with original manufacturer information on it and I've tried contacting them but they say "sorry not available". Its also not available from the usual suppliers (RS Components/Element14/Digikey).
So if can anyone help please with sourcing the part I would be very grateful.
Thanks for reading this... Ray
The schematic diagram does not seem to be correct but it is the only one I can find on the Net.
My VC3165 has the "B" input going via a cap to the MB506 chip, not the "A" input.
I seem to have damaged my B input with a bit of static and have ordered a new MB506 I.C.
The A input still works fine.
There are no back to back diodes fitted to the B input on my counter.
