Several things come to mind in your comment, Glen. (1) is the fact
that the T in the equation provided above actually isn't the only
effect that leads to using these junctions for temperature -- Is
itself is a function of temperature, enough so that it actually
reverses the sign of the rate of change. So the above equation
doesn't tell you the picture there. I can post the Is equation, if
you'd like (already done it before, here.) (2) at Vbe of a few tenths
of a volt and currents in the tens of microamps, self heating of the
die shouldn't be a problem, yes? And we are starting at around 300K,
after all, which means even for dT of 20K, we are talking about 6-7%.
(3) Is has a huge effect when comparing Vd of diodes and transistors.
(4) 'n' varies widely in diodes -- very widely.
So, would you please elaborate why you say that T is the most
significant variable?
Jon
Just to make sure we are talking about the same thing, the question as
I understood it is, for a given (forward) I through a diode at "room
temperature", what is the resulting voltage, Vbe? I will take "room
temperature" to be between about 65 and 85 F, (my winter/summer
thermostat settings), or 291 to 302 K. Since we are talking about Vbe
as a hopefully useful and repeatable function of I we should restrict
the discussion to diode connected small signal transistors having
decent gain over the range of currents considered.
Considering the approximation
I = Is(e^qVbe/kT - 1)
I = is the collector current.
Is= Emitter saturation current, typically well below 10^-13 amps
in a well made silicon transistor. Very temperature dependent.
q = The unit-charge constant, 1.602?*10^-19 coulombs.
Vbe = Base-emitter voltage.
k = Boltzmann's Constant, 1.38062*10~-23 joules/deg K.
T = T-absolute, K (273.15 at 0C).
Then (neglecting the -1):
Vbe = kT/q ln(I/Is)
Vbe varies directly with T, at approx 2 mV per degree K, or about 22
mV over "room temperature"
Leaving the question, how much does Is cause Vbe to vary. Is is not
included in many transistor data sheets, but from my notes I have a
few data points at 25 C for some transistors commonly used for logging
(source unremembered):
Tr Vbe @ 1 mA Is
MAT01 .63 2.2 * 10^-14
MAT03 (PNP) .585 1.3 * 10^-13
LM194/394 .58 1.6 * 10^-13
MAT02/04 .57 2.3 * 10^-13
So, with around 60 mV variation due to Is it looks like you were
right! But IME with the transistors I have used for temp measurement
such as 2n2222a or 2n3906 the part to part variation due to Is has
been much less than the variation over the range of "room temperature"
- I think the MAT01 comes closest to your typical high gain small
signal transistor; the others listed have relatively large dies for
low bulk resistance resulting in better log conformance at higher
currents.
But any way you look at it, T cannot be ignored even over the range of
"room temperature".
Glen
