Varistor
Discussion in 'General Electronics Discussion' started by viki2000, Jun 18, 2013.
  1. viki2000
    viki2000
    Jun 18, 2013
    Varistor, Voltage Dependent Resistor (VDR), Metal Oxide Varistor (MOV)…
    I need one and I have difficulties to find it, to know if what I need/want really exists in reality by various manufacturers…
    Basically I need one resistor which is 56K at 100V and is 112K at 200V.
    The main problem that I have is: based on resistor value at certain voltages to identify that varistor (if exists) in the data sheets of the manufacturers.
    In the data sheets or catalogs or web pages of varistor are all kind of parameters, but I cannot search varistor based on their basic definition: value of the resistor ta given voltages, a curve.
    How do you find/identify the varistor based on resistance/voltage variation curve at manufacturers?
    If you know one manufacturer, could you provide some examples?
  2. (*steve*)
    25,497
    2,838
    I doubt you can get a varistor like that. For a start, their resistance will fall with voltage.
    However, what you describe sounds like a 1.8mA constant current source, which is not that difficult to create.
  3. Harald Kapp
    11,517
    2,652
    A varistor normally works the other way: high resistance at low voltage, low resistance at high voltage.
    Your requirement sounds like what you really need is a constant current source: I=100V/56kOhm=200V/112kOhm=1.78mA
