I'm having a Senior moment. I want to add a current meter to a 10A Variac. My thought is to add a series/shunt resistor and then a rectifier/cap. to the meter. The meter draws 104.5uA @ .05Vdc full scale.The Variac puts out 1 to 140 Volts. What I initially come up with is .01 Ohm @ 1 Watt but I know that doesn't factor in the voltage drop across the rectifier.
