Good morning,
I am making a simple AC chopper for a dimmer circuit for a table lamp. It consists of a simple Triac which is fired using a RC circuit with a variable resistor. I've attached the schematic.
My problem is that instead of using a potentiometer like in the circuit, I now want to control this circuit using a microcontroller to vary the resistance. The problem is that there is 220vAC flowing through the variable resistor and I obviously have a control signal of 5vDC coming from the microcontroller.
I have controlled AC switches before using DC control circuits by using simple relays which have 2 completely isolated coils. What I'm asking is, is there a similar way to control a variable resistor?
I've been researching photocouplers, looking for a solution. But it seems photocouplers behave similar to relays (in that there are only 2 states, either on or off). Any help would be appreciated.
Thanks !
Thanks !
