variable HF oscillator
Discussion in 'Electronic Basics' started by Nelly, Jun 1, 2007.
  1. Nelly
    Nelly Guest
    I need to vary the frequency of operation of a transceiver IC from
    7MHz to 9MHz. The oscillator needs to feed into the crystal
    oscillator input and crystal oscillator output pins of the IC (the
    current design does not have a variable oscillator and is just using a
    crystal). Ideally I would like to control the frequency of the
    oscillator using the PWM of a micro controller (unfortunately the
    current micro does not have a DAC). Any ideas on the best way to do
    this?
  2. rec.radio.amateur.homebrew would be a better place to ask for this
    help.
    prove it.
    Member of DAV #85.
    Michael A. Terrell
    Central Florida
  3. Don Bowey
    Don Bowey Guest
    Many xtal oscillator circuits work well by just replacing the xtal with a
    series LC network.
    Don
  4. Jamie
    Jamie Guest
    You can emulate PWM output with the processor.
    all you need is to use a timer (IRQ) driven to
    generate the output pulse on the pin of your selection.
    Normally the IRQ rate is put at multiples of the shortest
    PWM pulse you may generate. With this, you simply use a
    scalar counter to adjust the output duty cycle.
    As far as the OSC goes, you can replace the Xstyle with an
    LC and Variac tuning diode assembly how ever, I don't know
    what you have planned to monitor the freq for stability?
