Variable frequency sound emitter
Discussion in 'General Electronics Discussion' started by taylor, Jul 3, 2012.
  1. taylor
    taylor
    Apr 12, 2012
    Hi all,
    Part of a circuit I'm working on now for a model rocket launcher ignition system has 1 buzzer that sounds when the launch button is pressed. I'm thinking about adding another buzzer that sounds at two different frequencies back to back (low -> high) when the system is started.
    here is my circuit as it stands:
    [​IMG]
    I would like to have the 2 tone buzzer sound after the first switch (key switch/S1 in the schematic) is closed to signal that the system has started. What would I need to accomplish this? Would it have to be some kind of logic gate that allows 2 different voltages to flow to the buzzer? I'm very new to electronics so forgive me if I sound markedly uneducated :p
    As you can see the supply voltage is 12v.
    edit: in case you're wondering the load resistance at the end is the ignition load
  2. KJ6EAD
    KJ6EAD
    1,114
    159
    Aug 13, 2011
    There are many ways to do it. I might try to use two 556 dual timers or even a single 558 quad timer. That would give a total of four timers. The first timer would be configured as a monostable to set the duration of the sound by enabling/disabling the second timer which would alternately enable/disable the third and fourth timers that are configured as astables (oscillators) to produce the high and low tones.
    For more information, research the 555, 556 and 558 timers.
