variable-frequency power source?
G
George
We need 120Vac @ ~10w, adjustable (and fairly stable) over 50-70hz.
Cost is an issue.
Among other ideas:
- std signal generator -> audio amp -> step-up transformer.
- modify a UPS, so the frequency can be adjusted.
Does anyone have any experience/thoughts on these, or other better
ideas?
George
M
martin griffith
Cost is an issue.
Among other ideas:
ideas?
George
What distortion can you tolerate?
martin
T
Tam/WB2TT
Cost is an issue.
Among other ideas:
ideas?
George
We used an audio amp and a signal generator. At 20W output you can use a
12V 2 amp filament transformer. Cheap.
Tam
B
Barry Lennox
Cost is an issue.
Among other ideas:
I recently used the first route, an HP200CD, a Quad 405 Amp into a
15-230vac transformer. It worked very well, but I did require a
decent resistor across the amp output to keep it stable at all freqs
(from 16 to 400 Hz)
Barry Lennox
P
Pooh Bear
Cost is an issue.
Among other ideas:
Been there done that.
The amp isn't terribly happy with a typical psu on the output. Tends to
trigger the protection.
Graham
G
George
Fairly gross: ultimately, the object is to simulate a gas-powered
generator.
George
