bertrand lapointe said:
Hello to all,
I am interested in your comments about VFD.
Which brands are the best for you and why ?
Which brands are the worst for you and why ?
Which brands last the longer.
Which brands failed faster.
On what application ( s ) are you using them
What AC line voltages
What HP range
What environment
Would you suscribe to a Drive News Group ?
Written as a UK based automation engineer....
Mitsubishi............................................
We always use Mitsubishi drives unless something
else is specified by the customer...Why this is I'm
not really sure. They seem to be a reliable drive and
I have only had a couple fail on me in about 10 years.
I also like there support, where u can call up and speak
to an engineer, where as some brands u call up and they
take your details and get an engineer to call you back in
half an hour (which ends up to be two days)........
Schneider/Telemechaniqe...........................................
Very good drives, but seem a lot more sensitive on back
emf on motor braking......would seem to need a long decel
time on a pushing load without a breaking resistor.
Klonker Moeller.............................................................
Only used once or twice but seem very basic.
Control panel and display was hard to get to grips with
but a handy shortcut card was slipped in a small slot on
the top of the drive...could be very handy on site when
u have no manual.
GE...................................................
Cheep and worked well, had to make several calls
to Spain to set the thing up...didn't seem to have any
'real' technical support in the UK.
ABB................................................
Have only used these on the big drives about 100-200KW.
Were a joy to use and set up. Nice screen and very informative
display. Only downside was I installed 4 of these @ 110KW
and one failed after about a month
This is just a small sample I can remember off the top
of my head. Working at UK mains voltage, about
415V AC 50Hz. Load sizes from 0.75KW - 200KW.
Would you su'''b''''scribe to a Drive News Group ?
Yes I would.
sQuick..
