Variable duty cycle and frequency with a 555
Discussion in 'Electronic Design' started by captoro, Apr 25, 2013.
  1. josephkk
    josephkk Guest
    Some do, more don't. Now catfish is a real dung eater. Don't trust me,
    check it out for your self.
  2. captoro
    captoro Guest
    edge speed ??? you mean harmonics ??
    K
  3. Martin Brown
    Martin Brown Guest
    The obvious question is why would you bother?
    The faster waveform rise time means that the higher harmonics of the
    fundamental remain significant. In the limit that the waveform becomes a
    delta function like spike then all harmonics are present with equal
    weight. A real narrow pulse has finite width. I presume this is a device
    designed to destroy MOSFETs and CFLs in roughly equal numbers!!!
    BTW be careful if you end up flashing bright lights at frequencies in
    the 5 to 15 Hz range as if you are even slightly prone to epilepsy at
    the wrong frequency you could end up on the floor twitching in a fit.
  4. Fred Abse
    Fred Abse Guest
    What do they feed those? Sure it ain't made from chicken droppings?
  5. josephkk
    josephkk Guest
    Not perfectly, but yes. The fast edges mean lots of high order harmonics.
    To help with the idea 1 microsecond edges mean plenty of 1 MHz range
    content, likewise 1 nanosecond edges mean plenty of 1 GHz range content.
  6. josephkk
    josephkk Guest
    Hmm. Make that omnivores, the eat grain as well as worms, grubs and
    insects when they get feral.
  7. amdx
    amdx Guest
    I find it difficult to read by that light.
    Yes, it reminded me of my 7th grade English class,
    Boring.
    Mikek
  8. amdx
    amdx Guest
    I got the impression that the core was a little bit jumpy!
  9. amdx
    amdx Guest
    sci.electronics.you.ask.i.won't.answer
    sci.electronics.do.the.math
    sci.electronics.i.don't.know.the.math
    sci.electronics.phil's.angry.name.calling
    sci.electronics.how.far.can.a.thread.drift
    Mikek
  10. How about solution-oriented newsgroups? Eg.
    sci.electronics.555
    sci.electronics.PIC
    sci.electronics.sallen.key
    sci.electronics.howland
    Problems should be posted in an appropriate group for that solution.
  11. Ralph Barone
    Ralph Barone Guest
    sci.electronics.12.angry.men (plus or minus a few)
  12. Bill Sloman
    Bill Sloman Guest
    Then we'd need another group
    sci.electronics.tell-me-how-to-define-what-I-think-I'm-trying-to-do.
    Mike doesn't realise that this is actually an alias of
    set up for mutual admiration sessions between him and Jim.
