variable capacitor
Discussion in 'Misc Electronics' started by exxos, Nov 14, 2003.
  1. exxos
    exxos Guest
    Hi all,
    Is there anywhere ( lik ein UK ) which sells variable capacitors but the
    shaft types ? RS seems to sell everything in preset pack only. I've checked
    around google and theres not much there by the looks of it.
    thanks
    chris
  2. Wim Ton
    Wim Ton Guest
    http://www.mainlinegroup.co.uk/jacksonbrothers/index.htm
    Wim
  3. Mjolinor
    Mjolinor Guest
    I suspect that when you find one you will quickly decide they are too
    expensive, the only source I ever found that would fit within the cost
    constraints were secondhand ones.
