P
packrat79
Some years ago, I built the flyback tester that was described in
Sams FAQs - the one with the simple two-transistor oscillator,
connected by winding your own 10 turns onto the flyback core. The
flyback is of course tested out-of-circuit. Over the years it has been
quite accurate, but the results with one recent flyback are rather
inconclusive, and I thought maybe you could give me some advice.
I don't have the model # of the set handy, but it's a 36" Sony made
in 1998. It came in with a blown HOT and switching regulator, so
naturally the flyback was the first thing I suspected.
Normally when a flyback is tested with this device, it will produce
a decent-looking arc of about 1/2". The flyback in question, however,
seems to produce a weak arc of less than 1/4", and it doesn't have the
"sizzle" and thickness I normally see with this test. Given the size
and high voltage requirements of the CRT, I expected a lot more from
this flyback (if it's good, that is). Would I be right to suspect it
as bad?
I really don't want to replace the other components and leave the
original flyback installed, because if it's bad, as you know, it will
just take out the other components again (nice design, Sony).
Any advice would be appreciated.
as bad?
