P
Phil Allison
"Tim Shoppa"
It is not too uncommon to use tetrodes or pentodes in "triode mode" by
tying the grid and screen together.
** That is completely false and will not work.
In "triode mode" the screen grid is tied to the plate while the suppressor
grid or beam plates are tied to the cathode as usual. The screen grid is
crucial to the operation of a power tube - if tied to the cathode the tube
will barely pass current, if tied to the plate you have a triode. If the
screen supply voltage is insufficient, the tube will not pass full current
and lack gain.
If the screen supply voltage is set too high, it will become the final
destination for far too many electrons and quickly burn out from
overheating.
That doesn't mean the screen grid
is the same as the control grid, in fact in beam power tubes the
screen grid is sometimes better identified as a "beam forming plate".
** Nonsense - see any tube data book for how beam plates are connected
internally to the cathodes of beam tubes, eg;
http://www.pentodepress.com/tubes/6L6.pdf
....... Phil
and lack gain.
overheating.
....... Phil
