Vacuum Cleaner Motor Control
Discussion in 'Hobby Electronics' started by Dan N, May 14, 2008.
  1. Dan N
    Dan N Guest
    I have an LG vacuum cleaner that will sometimes run, but mostly won't.
    I've opened it up and looked at the wiring and everything seems in order.
    There are two circuit boards, one would be the speed control and the other
    has a triac to run the motor. I ran the soldering iron over the board to
    reflow the solder and when I did so I could smell that burnt component
    smell. The smell seems to come from a capacitor near the triac, although
    there is no physical sign of damage.
    Questions.
    1. Should I replace the triac as well as the capacitor? Is it common for
    these capacitors to go? Would the vacuum cleaner working intermittently
    be a symptom of the cap being faulty?
    2. The cap says 01F. Am I correct in assuming that this is .01 uF?
    3. Where would I be able to get one of these? I've looked in the RS and
    Farnell catalogs and all the motor run/start caps are physically quite a
    bit larger. This one is about 15 mm in diameter and stands about 15 mm
    high. The markings on the cap are:
    BYDQ
    95/85C
    01F
    Dan
