Using Transistor as Momentary Switch
Discussion in 'General Electronics Discussion' started by sall, May 16, 2011.
  1. sall
    sall
    51
    Jan 29, 2010
    I am trying to figure out how to use a transistor to operate as a momentary switch. Right now I am using a relay, a cap and a resistor. I would just like to be able to make the circuit a bit smaller than using a relay.
    TIA! :D
  2. (*steve*)
    25,361
    2,756
    OK, so you need to explain more.
    What will cause this "switch " to close?
    Do you want it to stay closed for a brief period then open again?
    What is this period?
    What is the load that you are controlling?
  3. sall
    sall
    51
    Jan 29, 2010
    Yes, I apologize for the lack of information and hasty post. I have a relay setup so that it receives signal from 12V switched wiring in my vehicle and in turn acts as a momentary switch to power on my laptop any time the ignition is in accessories/run.
    [​IMG]
    I would like to do something similar with a transistor if possible to reduce the size of the circuit, but am unsure how to accomplish. I am planning on combining this along with other small circuits on one board for a carpc project.
  4. davenn
    davenn Moderator
    13,558
    1,854
    by the time you have a transistor or 2 and associated components on a cct board and then mount that board in an insulated case its probably going to end up being bigger in size than the relay system you are currently using.
