Hi there,
I'm using an MG995 servo, which is rated at 6v. To power it, I'm using 4 (new) AA batteries, which should provide 6 volts. The servo only comes on periodically, so to stop the batteries from going flat I've hooked up a solid state relay to turn power on/off to the servo.
The servo is running very weak (with fresh batteries) - is it possible that the solid state relay has a voltage drop or something that's causing this?
