using software i2c
Discussion in 'Microcontrollers, Programming and IoT' started by Jameston E, Feb 3, 2019.
  1. Jameston E
    Jameston E
    4
    Sep 19, 2018
    Hello everyone ,
    I am making a digital weight scale that will read and notify me when the weight is lower than what I want ...... I am using pic16f690 for the project and I later discovered it does not support i2c module, decided to use software i2c instead but after following the initialization, start, and read protocol of software i2c it's still not working
    Can someone please help with how I can go about it, I have searched the Internet and didn't find anything related that can help
    would be very glad if someone can help with step by step protocol process I should go about it and the address.....
    Don't really know if I got the protocol I used following the library well or it does not support what I want to do
    would be glad to receive your response soonest
    thanks in anticipation
  2. Bluejets
    Bluejets
    4,053
    847
    Oct 5, 2014
    If you go with Arduino it's as simple as.......just a couple of lines.
    One explanation here...(can start at around 11.00 if you don't need to know the beginning part)
  3. Harald Kapp
    10,025
    2,138
    I didn't know there are Arduino variants using PIC processors :rolleyes:
    You need to be more specific. How does "not working" manifest itself? Show us your relevant code (use insert code from the menu) and the relevant part of your circuit diagram. Check all portpins are correctly assigned and set up...
  4. Bluejets
    Bluejets
    4,053
    847
    Oct 5, 2014
    Well then I guess you are never to old to learn something new then.:):)
